Brake vacuum issues
Strato58
3:08 AM
New Jersey
How are you guys with a more aggressive cam profile fixing your factory power brake vacuum issues? Some times this cars brakes are so hard to push then just locks them up, other times its tame and normal. Right now its making this car very difficult to drive
I guess adding a vacuum canister is the way to go? How and where are are the best mounting spots on a b body? Trying to keep this as stock looking as possible
This is a timeless issue dating back to... WWII? Oil and water mix better than long duration cams (low vacuum at idle) and power brakes.
:lol:
:lol:
I know but so far there has been no answer on how you guys are fixing the issue.
Install a milder cam. Having safe brakes is more important than having a lumpy cam.
I went straight to the hydro boost system. You can fabricate your own vacuum chamber to install where you do have room. Be mindful of the power of atmospheric pressure when designing!
Get a vacuum gauge with kit so you can check your vacuum at idle and cruising, use the kit to check the booster, also make sure there are no vac leaks anywhere else, valve is working, no kinked or collapsed hoses. I installed a reserve tank, but they have limited effect.
In other words, since you didn't mention it, go through your brake system to rule out other possible gremlins, there are several of them.
I use a Leeds vaccum pump from PST
This is the one I've been looking at. I just don't want to add any extra holes anywhere to install.
