A518/A500 overdrive into 62 B body ?
rustytoolss
2:38 AM
New Franklin, Ohio
I have an A500 overdrive transmission. At some point I would like to install it into my 62 Fury. I know I will need to use a different shifter., and have a drive shaft made. But my question is, How well does it fit ? And if you need to do work on the floor pan, and how much. Any pictures would help.
Holly has Transmission support adapters and some decent you tube videos. Apparently you cand pound the pan and trim some tabs from the trans. Check it out.
I would like to. But unsure of where you found these videos link ???? also is this for 62-65 b body or general information ?
I believe the upper half of the T bar cross member has to be rebuilt for clearance. So, it's a cut and weld project.
I didn't think the undercarriage was much different for mid sized Mopars. The Holly video is a 66 Charger and they say you only need to beat some clearance dents into your trans tunnel and trim a couple unused tabs off the transmission.
'66-up have the engine & trans 1 5/8" rearward than they were '62-'65, so around the bellhousing area there's more room in an early B.
But the early B has a smaller driveshaft tunnel, so the gearcase area may be very tight, likely too tight.
'66-up have the engine & trans 1 5/8" rearward than they were '62-'65, so around the bellhousing area there's more room in a later B.
The 500/518 etc trannies are much more portly on the back end of the main case than the 904/727's. Then there is the actual OD/Tailhousing unit. Crossmember surgery is a must plus there is potential for floor re-work too. On my 65, I'm using a 70 k-frame which moves the engine/trans back like 1.5". Doesn't sound like much but I had to work the floor some just to clear areas of the 727 case. There was maybe a finger gap around the trans for airflow. Pretty tight. It can be done, but its not a slam dunk.
