Too much end play after rebuild
rklewis1005
6:14 PM
Ok, so went through the Tom Hand book, rebuilt everything, took my time during reassembly, reviewed my disassembly pictures as I reassembled - paying special attention to thrust washers and anything that didn't look right (many other posts as I went along), and guess what - I have too much end play.
When I measure pulling the input shaft back and forth it's ~ .099. When I measure flipping the transmission over (so the output shaft also moves a tad", it's .15.
I'm measuring endplay using calipers and a steel tube across the bell housing. Same tube each time, oriented the same way (sharpie) to ensure consistent measure point.
So what's the most obvious thing to look at as I disassemble it? It seems to me there is a lot of movent in the clutch packs s as I can see the part inside move (pic). I have a 3 thrust washers left over (pic) and they are all ~ .062 thick. I replaced all but the one under the sun gear snap ring (the book didn't seem to rebuild the sun gear) - but maybe I missed it.
We're headed out camping today so won't disassemble until Sunday afternoon.
Are there thicker thrust washers I should use? Any part numbers/urls to buy thicker ones are appreciated. They all seemed to match the original thicknesses and end play on input shaft was ~ .063 before rebuild.
I have all original thrust washers as I was doing 1 for 1 replacements.
Any thoughts on typical screw ups is appreciated.
Ross
Ross
I believe the adjustable washer with sizes available is the one on the pump. You just look for wear otherwise. A little wear on all the washers is just a normal thing with use, just adjust the pump washer thickness.
Where do I find thicker ones?
Ross
I have rebuilt a lot of 727's, but do not recognize the thrust washer at the 2 o'clock position in your picture. If you can get the snap ring on the output shaft, with about .010" clearance, the rear stack-up is O. K. What are your front and rear clutch pack clearances. I suspect that you might have left out the .086" phenolic washer under the oil pump. With that back in, your endplay would be around . 013" .
I'll double check, but fairly sure I put a non metal thrust washer on the back side of it. Seems to me it was closer to .062
The small washer with 3 tans started up in the late 70's. The back of the rear clutch is clearances for this. Did that washer fit in your trans?
What year is your trans! a 1970?
Dod you put a small washer on the end of the output shaft before you put the clutch packs in?
Factory was dark brown fiber, aftermarket sells a bronze one with oiling slots. Either is fine.
Thanks, I'll check those out in my pictures and as I reassemble
I rebuilt my 727 about 8 years ago and had an excessive end play issue. Understand I’m not a transmission mechanic so this may fall in the apples to oranges category for your problem. But in short here is a cut&paste of what I eventually found was causing my excessive endplay.
“Started back to work today on the 727 despite bad allergies - but quickly ran into another possible worn part I have overlooked. I focused on the front planetary so much that I overlooked wear on the back side of the rear planetary where it rides against the #8 steel thrust plate in the annulus gear. There's a pretty good groove worn there that pretty much matches up with the thrust plate.
It measures a little more than my .035 in feeler gage which probably accounts for most of my excessive end play in the planetary train. I did check the #8 shim thickness and it mics at .036 so it seems to be in shape. So basically the planetary is riding on the annulus case instead of the thrust washer.”
I replaced my rear planetary with a new one and then my end play all fell into spec. The wear on the back of the planetary was so smooth and consistent that I thought it was factory machining so it didn’t jump out at me immediately. But, you could be looking at a completely different issue.
Good luck.
Yes - in a 1970, date built of course is 69
I had another one in that position if your talking about on the end of the output shaft. The pic is where I'm talking about - I think I used the original washer there as I didn't have an exact match on the rebuild kit. You're saying that 3 tabs small one goes there?
Just use the round brass or Phenloic washer there. The one with the tabs won't work, if a 1970 trans.
Good luck.
As I mentioned, I did not take the gear & washer out of the sun gear ( the book seemed to skip that). I'll take a closer look at the thrust washer on it as I disassemble it. I'm not sure the thrust washer kit had a replacement (see pic of what's left) as isn't that one flat (no tabs)?
Post #1. Clutch pressure plate does not look fully seated. One clutch plate not engaged?
That's with the input shaft pulled out as far as it can. It goes back and feels fully seated, but clearly it shouldn't move that much.
Good you have a washer there.
Yes the 3 tab washer goes there in a late 70's trans, it won't fit your 1970.
Take that sun gear apart and look inside. You need to inspect the gears and look at the thrust washer. Leave no stone unturned inside a trans. Especially one wothnwrong pieces inside like yours.
Something is wrong there. That is NOT fully engaged, and the sun shell will wear if run like that.
Try a thicker fiber on the back of the pump. Kim
I have one on order but it will be a few days.
When we get home tomorrow, I'm going to carefully disassemble and review this thread. Going over everything again carefully (again) and taking pics during disassembly/reassembly.
There should be a .062" and a .086" thick phenolic washers in the front end assembly. You can buy thicker nylon ones as needed.
