Fuel Pressure Regulator Connection & Mounting Edelbrock AVS2
I thought that factory used a smaller return than the feed. I’ll have to double check.
I would skip the regulator if possible. I doubt you will have issues as the edelbrock pump is supposed to be the same one as one of the carters. I ran the eddy pump with no regulator since it was rated at 6psi and it never gave me an issue so I never checked the psi it put out. Could be different in the era of private equity though.
The booster design, venturi position, & emulsion hole positions in the emulsion tubes are determined by the carb company.....& the appropriate fuel level to give the correct mixture strength. Final result of all this is the carb company providing the float level adjustment to provide the correct mixture ratio. If you raise the fuel level via float adjustment, you richen the calibration...& vice versa. You do NOT increase the fuel level in the bowls to maintain mixture ratio. You provide adequately sized n/seats for THAT engine, & a fuel delivery system [ pump & lines etc ] that can deliver enough fuel to the carb with some reserve capacity. D. Vizard claims that a change in fuel level of 0.100" is worth about one main jet size.
Still hoping one of you has a good photo of a clean looking regulator install for the AVS2 carb in our cars (bonus for including a Performer RPM intake).
If you decide to do it before, not after, this is where I mounted mine. One is a return, the other a dead head. At first glance, you don't even see them. Obviously, the orange car isn't together yet.
Good luck!
Good luck!
those both look like CLEAN installs. I like that 270 degree fitting! Thanks.
Which car is the deadhead setup and which is the return style? At first glance I suspected the orange car has the return - if so, I would love to see the line connection at the pump that comes from the regulator.
Don’t have a picture with an AVS.
When I’ve done mine, I have found that the Russell and/or Earl’s catalogs helpful in generating ideas with their fitting options. Maybe look there for ideas.
Personally I feel you're overthinking this. Just throw the carb on with a single feed and no regulator. I doubt you're running enough HP to run into draining the bowls on a single feed, and mechanical pumps do a great job without an external regulator. Then if you start running into heat soak issues start with a phenolic spacer.
Thanks, I agree my HP is not high enough to drain the fuel bowls with a single feed, but Edelbrock specifically mentions to limit fuel pressure to 5.5 to 6psi max, which has been confirmed by many other users from what I'm reading on reviews. I might get away with no regulator with the Edelbrock AVS2, but I want things optimized, so if I swap in the AVS2 it will get a regulator.
Do you have any experience with the AVS2 you can share?
I'm also not in a hurry. I have little free time and just tinker on this when I can find time once every few months. I really enjoy seeing other owners clean line installs though no matter what I'm working on.
You are mistaking the reasoning behind Edelbrock's 6 psi recommendation. Look at a Holley carb with sight plugs in the bowls for fuel level adjustment. Take the old #3310 Holley. It came with #72 pri & #76 sec jets. That was the 'best guess' jetting for a universal carb [ fits anything ] with the fuel level adjusted to dribble out of the sight plug holes. With the H carbs, fuel pressure can be whatever....as long as the fuel level it is adjusted to dribble out the holes...
E carbs do not have this adjustable feature, so a fuel pressure number is provided with a float setting number to provide the correct fuel level for the jets/met rods. Edel has NO IDEA what engine you are putting this carb on & is providing you with a starting point.
If fuel pressure is higher, use the chart in post #7 to increase the float level dimension. And vice versa. I have never found these carbs to be overly sensitive with 50 yrs experience with them. Think about what is happening to the fuel level during.......accelerating hard, braking, cornering, hitting a bump. It is all over the place....
It's not a good idea to put a diaphragm-type fuel pressure regulator on a mechanical pump, it stresses the diaphragm from cycling every time the cam lobe releases the pump spring.
Try drilling the return orifice larger in your fuel filter to relieve more pressure.
If that doesn't work, and your pump is the rebuidlable type, put a weaker spring in it or cut the existing spring.
If you need more fuel flow, an in-tank electric pump with a bypass regulator is the ultimate solution.
I think the cleanest look is using AN fittings and braided fuel line. Once you figure out how to cut them, it is so easy to work with. If you are using a pressure regulator then OE appearance is out the window anyways so just use the AN. That 270 degree adapter is an AN type fitting you can get from summit.
Regulator is nice but not absolutely necessary for an AVS. I would mount to the firewall run braided hose and call it done.
That why I suggested the catalogs. My regulator sits under my air cleaner. I used braided lines and AN fittings, but on a Holley.
