lumbee
- 2:03 AM
- Jan 24, 2024
- Asheville, North Carolina
Hoping you all can give me your opinion on this. Do these flywheel teeth look bad enough to make it so that the starter won't engage? The issue I am having is that the starter only engages and turns the engine over about half the time. It doesn't grind or anything, it just seems to click like the bendix gear is trying to pop out just is just banging into the flywheel. These are about the worse spots on the flywheel I could find, which don't look terrible to me, but I'm not an expert. Maybe a 1/4 of the teeth have wear like this.
This is a 1972 Chrysler 400 with a manual transmission. I have tried three different starters and had the same behavior with all of them. I don't mind buying a new flywheel if I need to, I just want to make sure that is the issue.
Any info appreciated, thanks!
