69 charger c6d oem blue carpet color
Chargern69
9:18 AM
Sweden
Hi!
I'm looking to order a new carpet from ACC (RockAuto) for my 69 Charger as the current one is quite worn and miscolored. I am a bit confused, however, when it comes to which color blue is correct for my car. I unfortunately dont have a build sheet, but my fender tag says C6D which is simply "blue". Looking at ACC, however, gives me multiple options for blue:
* Aqua (seems too green)
* Bright Blue
* Medium Blue
I have gotten some samples for the original charger colors and some other blues, but the current carpet is darker than all three original options above, even under the door sill plates and almost seem to be closer to the "Shade 13 Blue" color that ACC provides.
Another issue is that I do not know if the current carpet is original to the car, or if it was changed when it was restored in the 90's. It may very well be incorrect. Therefore, I wanted to check if anyone else has a C6D Blue 69 Charger interior who could provide some pictures of how their carpets look.
In the attached images you can see the Shade 13 blue (the darker one) and the Bright blue, which was the closedt of the original (according to ACC) colors. I think the Shade 13 looks closer to what I currently have, but I find it strange that none of the original are close. Could it be that my current carpet is not original
Definitely agree that Shade 13 looks to be the closest, so I might get that one. It would be great, however, if I got a hold of someone who could share a photo of another C6D interior 69 charger, as I dont even know if the current carpet is an original color.
Thanks also for sharing the hamtramck interior book. Ive seen it before, and it makes me a bit confused, since ACC has multiple blue colors available for the 69 charger as "blue" carpet. I wonder if its correct that there were variations, or if they've taken various blue colors from different model and year mopars and just have them as the choice for all mopars. Not sure.
Give ACC a call and explain your situation, they may be able to answer your questions.
If you're pulling up the carpet there should be a carpet tag underneath.
Mystery Tags | For B Bodies Only Classic Mopar Forum Mystery Tags
Oh thank you for the tip! Do you have any resource for decoding the tags? I saw you mentioned some book which may contain the answers
Which book was that, the general field guide?
What codes do you need help with?
Sorry for the confusion, I was referring to your message in the thread you linked, in case I were to find a tag on the bottom of the carpet (haven't been able to look yet):
Thanks. MMC Detroit got back to me on the paper tag and said the same as you.
They say it's in their large reference manual but l don't have that one. If anyone has that manual can you send me pics from that manual.
Going thru the manual but it occurred to me that the door cards and interior door lock should be the same as the carpet color.
Let's see a picture of them up against your color swatches.
Saw you are from Sweden, not sure where you are from, but my ancestors lived in
Holma, Bärfendal, Göteborgs och Bohus
Bro Socken, Goteborg Och Bohus
Bokenäs, Goteborg Och Bohus
@The Rebel thank you for taking the time to look at the source material, really appreciate it. I had some time after work to go to the garage today so take some additional pictures. This time I included the sample called dark blue as you mentioned, but I do think it's too dark compared to the current carpet (which I don't know if it's original or not, however).
I also took photos compared to the top door panels but I realise as I'm making this post that you probably meant the lower door panel.. oh well, I posted a picture of my interior, hopefully it helps a bit with imagining the difference. Ill have to take more pictures next time.
The color samples on the door sill are (from top to bottom): bright blue, shade 13, dark blue
The color samples on the door panel are bright blue, shade 13, dark blue in that order
That's very cool! I live in the very south of Sweden so not that close, but I have been to the areas around Gothenburg along the coast, which are very beautiful. You should look into coming on the Swedish show "Allt för Sverige" and travel to Sweden to find your long lost relatives! :D
