pro451bee
Dont mean to a but hole but my god , these cars have the simplest suspension system ever, how the the **** guys. Some poeple need there tools taken away in my opinion.
Let's take a poll and see if anyone asked for your opinion.....
Simple or not, we all are free to do as we wish. There is no reason to berate someone that tries to learn. Nobody was born knowing everything.
Hell judging from the start of that sentence someone should take away your keyboard.Dont mean to a but hole but my god , these cars have the simplest suspension system ever, how the the **** guys. Some poeple need there tools taken away in my opinion.
...and send him back to school for grammar and spelling.Hell judging from the start of that sentence someone should take away your keyboard.
I can't tell if that is typed like that for comedic effect or not, so I'll assume yes.Sorry if I got everyone's panty's in a bunch
The proper spelling in this context is "panties", not panty's. There is a good reason for the IGNORE feature on this forum.Sorry if I got everyone's panty's in a bunch
Lol there's a thread still going from Monday and 3 pages later the guy won't flip his center link and reinstall it. The problem was announced in the 8th reply.Dont mean to a but hole but my god , these cars have the simplest suspension system ever, how the the **** guys. Some poeple need there tools taken away in my opinion.
How did that happen? Did it slam down on your hand while you were tightening the bolt?Same thing happened to me but unfortunately with different results. Hard lesson to learn about adjusting them with the weight on the wheels.
I see a jack under the a-arm. Was that how the front of the car was being supported or were there jack stands under the frame allowing the front suspension to hang free? Remove the upper a-arm bump stops to let the suspension droop fully and the new bolt and the adjuster block will slide right in. I lube it with anti-sieze compound. Tighten them up approximately equal amounts on both sides, drop the weight on to the tires, bounce it a few times and roll it a couple feet back and forth and measure side to side. Jack back up, adjust accordingly until you get it where you want and sitting level from side to side. The torsion bar doesn’t need to come back out.
I did have a jack under the control arm, but it really was not lifting anything. When I took that picture, I was trying to get the adjuster nut out and was trying to raise the lower control hoping it would come out.I see a jack under the a-arm. Was that how the front of the car was being supported or were there jack stands under the frame allowing the front suspension to hang free? Remove the upper a-arm bump stops to let the suspension droop fully and the new bolt and the adjuster block will slide right in. I lube it with anti-sieze compound. Tighten them up approximately equal amounts on both sides, drop the weight on to the tires, bounce it a few times and roll it a couple feet back and forth and measure side to side. Jack back up, adjust accordingly until you get it where you want and sitting level from side to side. The torsion bar doesn’t need to come back out.
I saw that, but is that for the pair or just one, the picture on their website shows one.kanter has them for $92. Not as cheap as I remember but still not bad in todays world. Probably not OEM but OEM isn't what it used to be either.
I bought a set from QA1. $134 for the pairlooks like 1 to me. Mopars are not inexpensive parts by any means, shop around I guess.
I was holding the socket with my left hand while turning the ratchet with my right. When it let go the socket fired back into my hand. The ratchet ended up about 10 feet away.How did that happen? Did it slam down on your hand while you were tightening the bolt?
I hope you heeled up well.I was holding the socket with my left hand while turning the ratchet with my right. When it let go the socket fired back into my hand. The ratchet ended up about 10 feet away.
