Coolant temp sensors
Eric Pearson
12:25 AM
Houston Texas
Ok anyone out there who has a Fitech 6 pack and Dakota digital gauges how are you pluming 2 coolant temp sensors. I really don’t want to put them in the radiator hose and a water neck spacer won’t work due to my a/c compressor is in the way! Any ideas are welcome! Thanks as always
What engine?
Aluminum one should have 2 ports. Or you could down to the block drains.
What do the sensors look like? Are they short or do they have a probe that goes in the coolant passage. Some sensors need a lot of room.
I have the Slant Six with a standard looking water outlet containing the thermostat. I drilled and tapped a hole into the water outlet for my second sensor. The water outlet had room for the sensor to stick in there. Now I have the dashboard temp gauge in the head before the thermostat and the after market temp gauge in the water outlet after the thermostat. I can physically see when the thermostat opens with this arrangement.
Thai you to all that have replied,unfortunately the sensors that I have to use are 3/8 npt and approximately 1 /8 in long. I’m using the CVF serpentine belt system so I can’t use the small 1/8 in npt port on the water pump housing. Also I can’t use a water neck spacer due to the location of the A/C compressor. Think I have a solution for this problem. I’m thinking that I can use a 3/8 npt Y and a short nipple to plumb them both together. Fingers crossed
Drill and tap that small hole to 3/8". It's aluminum-it's easy.
I thought the same thing on mine. I was trying to use a nipple plus a tee out of the head. Did not work for two reasons, 1) the two sensors were too long and met in the middle of the tee before getting tight, and 2) the water would never really get up through that contraption to put the sensors in water all the time leading to incorrect and erratic temps. That's why I went to two separate holes for the sensors.
Just to clarify.....I tried 1/4" NPT fittings first which led to the sensors bumping each other in the tee, then I moved up to 3/8" NPT fittings which physically worked but created a rather ugly mess and, more importantly, did not bathe the sensors in coolant properly.
