1 Wild R/T
It's pretty easy to separate carpenters from fags.... Much harder to separate two fags...I gave you the exemption....... I separated the carpenters from the fags with a crowbar![]()
Navy surplus.with a crowbar![]()
If you need the top of the cowl and the flanges why not section in the whole cowl from the floor seam just above the frame rail to the windshield posts, shame that didn't get cut 6" higher...
That would be my approach as well, issue is his donor is A/C & the car being repaired is non a/cWhat Wild is saying is the best way to clip that would have been to use as much as you can, sleeve the windshield posts and join that whole clip to the car about 6 inches up the windshield posts. You need all that sheetmetal off the new clip anyway. So you have to figure out how to use as much of that intact as you can. So you want to use the cowl from the clip, the area where the door hinges bolt on from the clip, everything. With the clip intact as it is right now, everything on it is jigged up correctly, try to use it without cutting it apart.
The less welding you do, the less parts you have to line up correctly. If you join one big part to the rest of the car, you only have do that one lineup (top and bottom of course). If you start cutting parts off and you have to graft 6 separate parts to your car, it's going to take a bunch of time, the welds won't look factory and chances are a few pieces may not fit correctly in the end.
The donor is back and cut to match. any concern or advice?That would be my approach as well, issue is his donor is A/C & the car being repaired is non a/c
Alright, good deal. sheet metal screws are acquired and rosette weld skills are moderate. I should be good to go. My door hinges are shot, so after those arrive I'll start cutting and prepare to mockupscrew it into place......... enough to hold it, but dont over screw it
mock up fenders, hood, ect........ the sheet metal will tell you everything you need to know
It all makes sense now. Now I'm debating leaving spot welds on the frame rail and PS floor unwelded and patching the floor after everything else is connected and in placeThat's looking good. Not as much welding this way, as Eldubb says it will tell you when it's right.
