Edelbrock Pro Flo XT
6872n73
1:16 AM
Oklahoma
Has/Does anyone have any dyno results of Edelbrock Pro Flow ET EFI manifold vs a single plane manifold?
I see a few people have used them because of fitment or appearance but I have not seen any dyno comparisons.
Runner length has to have some sort of impact, but how much?
No Dyno results, but drivability sure improved over a Standard 4BBL intake and Carb.
Engine masters tried to document/ dyno the difference between carb/ efi HP and concluded that the carb made more power due to the fuel cooling the port walls... it was enlightening , but not surprising. A well tuned efi should have way nicer driveability though
I agree drivability is going to better with the pro flo but some of that is EFI.
Dual plane or single plane - Carb vs tbi - the carb will have more max power every time, that's well documented.
I'm would like to see if anyone has done A to B comparison: ie; ran a pro flo or single plane and then installed the pro flo XT on the same base engine, heads, cam ect.
Edelbrock has a video on youtube with a lot of music and numbers with no specs and a wonky torque curve.
Engine Masters where are you?
