Help ID these 440 rods
Ben Treinen
9:21 PM
Detroit
Need help IDing these rods out of my 440, tearing down my motor home 440 out of my GTX due to poor engine build resulting in rod bearing failure, trying to do do this as well as I can for my first build. Thanks!
Never seen one of those.. what is that, a cheetah? Greyhound,, kangaroo lol....
I'd consider getting some LY's
Need help IDing these rods out of my 440, tearing down my motor home 440 out of my GTX due to poor engine build resulting in rod bearing failure, trying to do do this as well as I can for my first build. Thanks! View attachment 1938973
Looks like all aftermarket
KB pistons
CAT rods
Decent parts IMO
Depends how it was assembled & treated !
Hopefully you can save them …..
Mopar2ya!
John
Scat's logo looks nothing like the logo on those rods....
Cat's logo doesn't either...
I have no idea who's logo that is, they don't look very beefy or particularly well finished... I would probably trust a set of LY's over those particularly if a rod bearing has already spun in one of them... What size are the rod bolts?
Rods have 3/8 studs marked A1
I don't like the lack of beefiness on the big end. Good thing you are going through it I think, cheaper than fixing a failure.
Not a fan of those knurled rod bolts either. The knurling has to locate the cap. Maybe that's why it had a failure
Not CAT, (caterpillar) maybe C.A.T. (chinese, ebay specials?)
To me, brand is immaterial. If you've already had rod bearing problems with them, I'd consider them paper weights.
If you want quality Chinese rods with superior bolts and US machining, I'd look into Molnar h-beams.
When you mentioned it earlier I knew you weren't referring to Caterpillar. But there is a company called Cat Cams that sells connecting rods... Their logo looks like this... no idea why it's posting sideways..
But since you posted I took another look and there is a second Chinese company that just goes by Cat... Looks like a win...
Impressive detective work, unbelievable how cheaply this motor was put together
Most of the reviews I found of the cat stuff (rods and "4340" cranks) have been on corvette forums. They are not impressed. Chinese metal of unknown quality, and shabby machining.
In my opinion, Eagle doesn't have the best reputation either.
For a decent quality rod at a decent price, I'd suggest scat I-beams. Better yet: Molnar. For a complete stroker kit, I'd use 440 source.
For US forged, US machined rods, try Ohio Crank.
I'm curious. What do you have for a crank in that engine?
I would get new rods, H beam or a rod that uses bolt only [ no nut ]. The undercut for the bolt head on those rods seriously weaken the rod in a very stressed spot.
Cat brand would be my guess
Yes , CATs logo is a cheetah. Unless it’s a stock build , I’d look for alternatives. Most likely 5140 steel. Not sure if they make them but SCAT 4340 I-beams would work great for a HP street motor.
