Heater Box - 70 Charger
rklewis1005
10:16 PM
I'm now working on the non-AC heater box for my 70 Charger SE. Since there was a mouse nest and a lot of rust in it from sitting 40+ years, I bought a couple of used heater boxes for parts (generally listed as 68-70 heater boxes). As I've been sorting through the brackets and cleaning them up, I noticed a few differences. Just wanted to verify with the gurus here before I paint.
1. The fiber box itself seems to be 1/3 grey - is that normal for a 70?
2. The panel that has the fan motor mounted to it is Yellowish (anyone know a paint color that matches it). It's not just rusted, it's definitely a different color than the other 2 heater boxes
3. The fan is plastic - older ones seem to be metal
Ross
When I restored my 65 Belvedere box I gently glass beaded the surfaces and then sprayed it with a satin clear. I was pleased with it's appearance.
The box should not be half gray. They were not painted, bare "plastic" of some sort.
That metal piece was bare when it left the factory. It just looks rusted now, like most turn into.
Someone was playing around with that heater box.
My '70 Charger is a non-ac car. I'll take a look at mine in a day or two, weather permitting, and take some pictures.
I don't recall anything being painted.
The yellow panel probably wasn't painted originally - was probably yellow zinc dichromate (spelling?) or something similar by the looks of it. If you can tell me if the fiber box is partially grey (not black) over by the vent that would be good.
Here is a very clean original non A/C box. The front cover is semi gloss black, that is the only paint on it. See the metal is bare, it has surface rust starting in the area of the motor.
Mine is grayish black kinda like the air grabber box. @dadsbee should have pics
Here is a different one. Look how there is more rust around the motor, and less rust away from it.
Ross
My weather should be sunny tomorrow. Would you like pictures of mine?
Sure, but to be clear, mine = a picture of your car's heater box :lol:
The more pics will make it easier. Please include the year of your heater box (hopefully a '70). I did notice my heater core has 2 different size tubes 1/2" and 5/8" (inlet/outlet) while the older ones have both the same size (5/8"). Do they sell the smaller reproduction hoses for that smaller tube?
About your plastic wheel...I am on the back end of restoring the factory non-A/C heater box for my '70 Super Bee. It had a scheduled build date of December '69. My heater box has a plastic wheel. The stamped ink part number on the front panel is 2936681.
I have another heater box from a '70 Coronet which has a metal wheel. It has a stamped ink part number of 2936680.
There is only 1 part number in the parts manual: 2936680.
From my research:
2936681: US market before Jan 1970 (also used in Canadian market?)
2936680: USA (only?) after Jan 1970
Possibly the 681 had the plastic wheel, the 680 the metal one? Or maybe it was jus the luck of the draw depending on which vendor supplied the wheels for a given factory.
Sidebar: I believe that this is the best description of the "plastic" box material; "thermal plastic with sisal fiber added for strength"
I still have the stamps for the boxes if anyone needs them
Pay the postage to and from. And you are welcome to borrow them
I saved our conversation from last time - I will be taking you up on that offer very soonl.
I don't see it already covered, although I might have missed it: up to '69, same size heater hoses. '70, up, two different sizes. Many vendors carry the repop hoses.
OK, heater box on my XP29N0G, D21 (4 speed=no a/c)
