Hey thanks for the info bud
Well the disassembly wasn't bad. Haven't really started the rebuild of all the components. I'm going slow and steady as it's my first time I had one plug break off the head (holds the kickdown lever pin in place). Spent several hours carefully drilling, using an easy-out, and applying heat to get it removedWhy does it always look like a simple process when someone else is doing a trans rebuild?![]()
It's what came with the car. I'm considering buying a stamp to put the part number back on one of the blades.That fan will be the best cooling fan profile that Chrysler put out!
The reproductions are fine, but don't have the correct finish. They are zinc plated, and I think originals were galvanized or similar.Any reason to repair the fuel filler tube vs buy a new one? It has some holes towards the bottom. Are the ones from Classic Industries ok?
