Restoring grille
KohrtRacing
9:19 PM
Colorado
Restoring my 68, soon to be 69 grill I’m not trying to get it to show quality, just wanna give it a refresh to make it look respectable. What’s the best way to attack this? Simply rattle can over it?
I also have some plastic cracks to seal. JB weld? Or a stronger, better option?
SEM adhesion promoter after cleaning with wax and grease remover after scotch brite. I used rattle can and steps above worked for me
First off, I'm confused. You note: "Restoring my 68, soon to be 69 grill"... Uh, the two grilles are different. Are you saying you're trying to make a 68 grille into a 69 grille ?
Oh yeah, picking up one of these cheap on fb marketplace. Not sure what else is involved in the conversion outside of the chrome, but we’re gonna make it happen.
Howdy When I repaired my 70 Charger grill I used PlastiFix it worked great. Now it took a lot of filing and sanding and painting, spray can, lots of testing to get the colors that I found acceptable. I've asked people to find the repairs no one has so far.
I'll be watching this thread as I'm about to start on mine I don't want to hijack your thread; however, if anyone has thoughts on the below.
1. Anyone successfully separate & reattach the plastic from the headlight door metal frame? There are smash rivers holding it in place and I'm wondering how much rust is behind it & is it worth the trouble?
2. Has anyone soda or walnut blasted them to clean off all the old paint? If you didn't can you see differences where the paint is chipped/worn between the fins?
3. I've seen different people say Semi-gloss & Gloss for the black. Is there a definitive decision what it should be? I read the David Wise judging manual and it's not specifically mentioned.
I have a spare grill (worse shape than mine) that I'm going to test the 3 questions on to see how it goes. One of the doors had sheet metal screws holding the plastic on the door frame so easy to try re-riveting it. And yes there was rust behind the plastic near the rivet holes.
Ross
Appreciate this thread. Starting my conversion/restore now. The only thing I’m noticing right now Immediately is that the hood latch release is in a totally different spot, thankfully, because it’s a race car, it doesn’t even apply.
Color wise, I went with a recommendation of satin black from rust oleum for the black and the Krylon aluminum color spray. We’ll see how they turn out.
Also unsure, I know every grill plastic centerpiece that I’ve ever owned had black on the bottom, this one is white for some reason. Not sure if a previous owner did that or what? Will obviously be painting over it.
