- 12:34 PM
- Apr 13, 2012
- Granite Bay CA
Most of us have heard of the increase in flat tappet camshaft and lifter failures over the last 20 years. Some of us have actually had it happen, even more than once.
I have. FOUR times too.
The blame has never been able to be attributed to one issue but is often spread around a few things. The reduction in the Zinc in the oil, stiff valvesprings, too little taper in the lobes or the lifters, improper break in, etc.
I've read that extended idling is bad since the cam relies on splash oiling from the rods spinning and spitting oil past the bearings. This is the reason why during camshaft break in, the RPMs need to be above 2000 to properly supply oil to the lobes.
Here is the question....
Once the cam is broken in, what harm is there in idling? The engine is under no load and there still is some oil being thrown around.
What about when you're rolling down the road and the RPMs are under 2000 RPMs? People with overdrive transmissions can be rolling down the road in 5th gear and be under 2000 RPMs for a few hours at a time. I do. I have a 3.55 axle gear and a .64 overdrive with a 26" tire.
I was out for a drive today and as I saw 1500 RPMs, I wondered if it could be doing harm.
There is a roller cam on the shelf that I intend to swap in over the winter but this issue of low engine speed at cruise has me curious.
