Here is a question for the flat tappet cam guys....
Kern Dog
Life is full of turns. Build your car to handle.
1:42 PM
Granite Bay CA
Most of us have heard of the increase in flat tappet camshaft and lifter failures over the last 20 years. Some of us have actually had it happen, even more than once.
I have. FOUR times too.
The blame has never been able to be attributed to one issue but is often spread around a few things. The reduction in the Zinc in the oil, stiff valvesprings, too little taper in the lobes or the lifters, improper break in, etc.
I've read that extended idling is bad since the cam relies on splash oiling from the rods spinning and spitting oil past the bearings. This is the reason why during camshaft break in, the RPMs need to be above 2000 to properly supply oil to the lobes.
Here is the question....
Once the cam is broken in, what harm is there in idling? The engine is under no load and there still is some oil being thrown around.
What about when you're rolling down the road and the RPMs are under 2000 RPMs? People with overdrive transmissions can be rolling down the road in 5th gear and be under 2000 RPMs for a few hours at a time. I do. I have a 3.55 axle gear and a .64 overdrive with a 26" tire.
I was out for a drive today and as I saw 1500 RPMs, I wondered if it could be doing harm.
There is a roller cam on the shelf that I intend to swap in over the winter but this issue of low engine speed at cruise has me curious.
Do you think there is any credence to this QS oil being excellent for a flat tappet engine? And possibly break in procedures being done improperly thinking it was the way to go for all these years? Is the oils high film strength a reality? Its amazingly high in PSI. Maybe this blog shouldn't be poo pooed as much as it has.
https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
I've read, here on site, that excessive idling is not good but that was intended to mean 700-800 rpm idle and then turning the engine off. Like you stated 2000 rpm long hauls at 70-75 mph are common and have had no ill effects on my cars.
I worked for a large engine builder. We had 3 wet spin stations. Every long and short block got hooked up to a warm 45psi oil supply and spun at 800 rpm. We adjusted valves and checked compression I can tell you that without an oil pan or intake the amount of oil spun up on the cam was amazing.
I see no harm in idling. It [ wear of lobe & lifter surface ] is about the amount of time that the two parts are in contact. Taxis can spend a lot of time idling at the taxi rank, yet the engines are known for long life.
I never had a cam go flat until after they changed to the API SL standard in 2001. They already had started lowering ZDDP levels in 1996 to 1,000 ppm of ZDDP (API SJ), but I don't recall having issues until the new SL which was still 1,000 ppm ZDDP, but something else changed, maybe deposit control? maybe more detergent in the oil?
When I put the 360 in the Coronet, I will be using the Driven Hot Rod 10w-40 oil.
I think it's worse with older carburetted cars than modern computer controlled engines. Fuel wash from rich idle mixtures, diluting the oil.
I don't like idling mine when cold either. The idle rpm is lower and the oil is thicker so I reckon the oil flow will be less.
Back in the 60's-70's Cop Cars would idle for hours even days without being turned off. (before roller cams were standard) Officers I knew said sometimes cars would run 72 hours or more not being turned off during shift changes,fueling etc.
That said, yes quality was better back then . This is a interesting debate.
Iron surfaces "work harden" with time so that will most likely explain why after a break in period cam material can withstand lower oiling conditions and survive.
Mike
I tend to believe this theory. But even idling, the crank is splashing oil all over the place.
My last flat tappet cam, a Hughes grind, had most of the lobe tops polished off and one polished down and that cam was idled quite ofter. It didn't have the best break in either, but it had a steady diet of Gibbs Driven Hot Rod oil. Hopefully my new Hughes cam (textbook break in, used springs, Gibbs HR oil) lasts longer.
While oil plays a role I think there are many available out there that remove that from being the problem. I believe having the lifters checked before running them for correct taper is the single biggest issue.Throw in too much spring pressure on break in and you have a recipe for failure.
The underlying thing with this issue to me is simple:
- For decades, we didn't hear (or experience) multitudes of cam failures in engines, rebuilt or otherwise.
Cams (and lifters) were made of certain metals (and were machined a certain way); oil was made a certain
way (all dino, of course).
Rebuilt engines were broken in the same way for the most part, too.
True?
Now...
- Can't hardly be in the hobby without hearing (and/or experiencing) about cam failures these days.
So...
- What changed? Manufacturing? Oil? Building processes?
Point is: Something changed to upset the apple cart - perhaps several things changed - but logic would say
when you are honest enough to point the finger at what actually changed in the process, you honestly
answered the question.
I have a decent .540 lift Comp Xtreme Energy 292 in one of my cars. It has over 65,000 miles on it now. I have idled it for hundreds of hours over the years since built back around 2007 at all of our Hines cruises, downriver cruises, east side cruises and Woodward Dream cruises never with any issues.
True?
Now...
So...
Everything has changed since then.
1. Camshaft profiles- much more aggressive than earlier grinds as we try to leverage all the benefits of the .904 lifter, more prone to failure if everything isn’t “right”.
2. Metallurgy and manufacturing- maybe not as tightly controlled as before as we’ve transitioned to a global supply market, poor quality materials and quality control.
3. Oils-more oils on the market and most without ZDDP additives to support flat tappet cams, and those with additives having lower amounts.
4. People and knowledge. You have a lot more people participating these days and most with a little to no understanding of how to successfully execute a flat tappet cam break in, and very few of those will take accountability and own the outcome.
I don’t think there’s any one smoking gun on this subject matter.
All of the above, every engine is different. One thing here, we all seem to agree that the rods have a lot to do with oiling the cam and lifters. Had an argument here 4 or 5 years ago with one of the engine builders here. Said that wasn't so. I just ended up walking away. He hasn't commented here yet.
What’s the saying?
Fifth time’s the charm?
My first two cam failures were almost 20 years ago. Both were in my 440/495.
We want to think that we did everything right to ensure long life but it is always possible that some fatal mistake was made without even knowing. One cam crapped out not long after break in, the second one lasted longer but I can't remember if it was a year. The 3rd failure was a MP 292/508 in a 360. I know the mistakes I did there and can't blame the parts. #4 was in 2022 and was most likely the oil to blame. In that time, I've also had successes so it isn't as if I killed every one I installed.
I did decide to switch to a hydraulic roller for my next cam but have procrastinated with the swap. I do intend to do it over the winter.
Out back I have a 67 Dart with a 360, a 72 Duster with a 360, Jigsaw 70 Charger has a 383 and the Power Wagon is a 440. All of them have hydraulic flat tappet cams with mild valve springs and none of them have wiped out their camshafts. They have given me hope that a flat tappet cam can survive.
Obviously, not every flat tappet cam install ends up in failure.
It just seems to be a riskier endeavor than it once was.
For the reasons brought up already.
Sounds like the 5th time was the charm.
In early 2020, I called what I thought was Racer Brown to spec a cam for a 383. I told the guy on the phone that I was worried about the risk of cam failures. The man said that he never heard of a cam or lifters going bad. He lost all credibility from there. This same line is spoken by others when you call to register complaints....This is the first I've ever heard of this.....
Really? I've heard people say this a few times, as if they are programmed to downplay their mistake and shift the blame to the customer.
I agree that sometimes, the customer is 100% to blame but to claim that after years of sales, no failures have ever been reported?
Agreed. I've been lucky in that I've only had one cam/lifter failure (440 engine, hydraulic cam) - and despite
all the usual protocols being followed (and using some of the fantastic Driven (Joe Gibbs Racing) high ZDDP
break-in oil, the COMP cam/lifter combo wiped a couple lobes in fairly short order.
By comparison, The current engine in Fred has a vintage (but new in box when bought) Mopar purpleshaft
cam and lifters (484 lift) that broke in just like olden days and has proven after a few thousand miles to be
just fine - you know, like it used to be.
I never vary from the Driven/Brad Penn/VR1 high zinc oils and always use the venerable Wix 51515 filter.
I expect no problems as a result - and will next time again seek out an older production, new in box cam
and lifters.
Pretty much that way about most parts these days, come to think of it...
