Rebuilding LemonWedge.
I know I’m bouncing around a little here, but just want confirmation from someone that’s removed torsion bars before. I’ve heard horror stories on this task.
Once I have the adjuster studs completely removed from the lower control arms; all should be safe, correct?
Remove the retainer clips from the rear of the bars / backside of crossmember. Clamp the tool onto the bar, and tap it backwards until it slips out of the control arms. Then remove the control arm. Then the bar should be able to slide forward far enough to remove it from the crossmember.
Sound correct?
Sound correct?
Yep. Or if there’s nothing behind the torsion bar (like a welded in crossmember) you can keep going right out the rear.
Mine has a crossmember added but the torsion bars will slip past underneath.
Sound correct?
If you're upper control arms are still attached, remove the bump stops under them to allow the lower control arm to drop that much more.
