440 Head gaskets and others
TheCouzin
11:32 AM
Alberta
Looking for advice on head Gaskets, valley pan gasket, intake gasket. I have Moroso (93055) valve cover gaskets already. Going to be getting rid of the K&N Air cleaner and finding a 440 one.
Dyno sheets from previous owner claims 542Hp and 574Tq. CR 10.27
Has 23-710-9 Comp cam
8921-16 lifters
1321-16 rocker arms
L2355f 30 Forged pistions
60929 Edelbrock heads.
Need more info like why are you changing head gaskets, and what was in there previously
Changing them cause I just aquired this car. Its been sitting for a while from previous owner, and is leaking from head gaskets slightly. And just to give it a good once over since its winter here now. Also going to be changing fuel pump gasket too cause its leaking but thats pretty straight forward.
I havent pulled the heads yet to see what they got on it now.
Need tear it down and see what the piston stick out is, measure piston to valve clearance. A typical FelPro .040 type head gasket should be fine but there might be some reason a thicker one might be needed. Or maybe a thinner and add some compression.
Ok. Awesome. Sounds like I am trying to get ahead of myself. Ill pull the thing apart and see whats on there and take some measurments. Cheers
