TTI exhaust install
Schultz64
7:03 PM
link lakes, mn
Greetings. One of my winter projects is installing the full TTI exhaust system on my 1964 Dodge 440. Is it best to work front to back? Pre-assemble some pieces? I will be laying on concrete with the car on jack stands.
front to back. Use band clamps. Way easier to adjust and you can take apart later if you need to remove a transmission
Actually I believe TTI recommends that you start at the back and make your way to the front.
If you’re using headers install those first. Then rear to front
I believe tti generally says: Back to front. Headers first. Then the system back to front. Good luck
They will include instructions.
