Machining Air Grabber Turn Signal Openings
Moparfiend
10:56 PM
HOT
Anyone here successfully opened up the Air Grabber signal opening in the cast material of the 70 hood? If so what did you use and your experience?
I unfortunately no longer have access to the Bridgeport. So its going to be air grinder and file?
Is this stuff magnesium?
Haven't done so, but my "go to" would be a Unibit.
Thanks Wayne. Yes that’s what I used to make the hole seen above. Ill see what it’s like to die grind it out and then file the flats out.
