- 10:10 PM
- Aug 18, 2024
- Virginia Chesapeake Bay
Is the O/D an electronic push button or an extra gear?
Post in thread 'A-833 overdrive options-' A-833 overdrive options-
Neither...I thought it was ratio changes for gears 1st though 4th with 4th being an overdrive ratio.I read that earlier. It didn’t tell me anything. Is there a button you push or an extra gear?
Button on mineIs the O/D an electronic push button or an extra gear?
0.78 don’t do **** for rpm’s. Maybe 200 reduction.IIRC it's .78 OD
I looked at those too. May have to revisit them. I quit looking when I saw a bench seat might be a problem and the price. Now that I know the gear vendors is electronic, I don’t want it.This was 5 years ago but I got a full auto conversion kit for around $5,500 on my 72.
Its going to depend on final drive and tire size but it should be more than 200rpm, example in photos below.0.78 don’t do **** for rpm’s. Maybe 200 reduction.
I used a similar calculator. For 410 gears and 26 inch tires it’s not that big of a dropIts going to depend on final drive and tire size but it should be more than 200rpm, example in photos below.
I think you've made a mistake in your calcs.I used a similar calculator. For 410 gears and 26 inch tires it’s not that big of a drop
You are correct. Still 800 rpm in my mind isn’t that much. GV advertises a .54 and .78. .54 would be more like what I would want that would put it at 2000. RPM at 70mph. But GV website doesn’t do a very good job of explaining the 4 different options they have. I also don’t like the idea of a button that needs to be pushed.I think you've made a mistake in your calcs.
For 4.10 gears with a 26" tire I get 2,900 rpm at 70 mph with a .78 O/D, and 3,700rpm with a 1:1 ratio at the same mph.
Tell me more. What exactly is the A833OD. Is that a factory Chrysler.I switched from an A833 to a cast iron A833OD for a cross country trip, thinking I'd switch back after we returned home.
Nope.
It's great, inexpensive, kept my bench seat, no hacking the floor, direct swap to my bellhousing, shifter, driveshaft.
75mph @2,100rpm with 3.23s and a 28" tall tire.
800 rpm drop is HUGE.You are correct. Still 800 rpm in my mind isn’t that much.
