to pasture....well, driveway. Sure miss driving it and well, going to talk to a couple of people to see if they can make it a bit more whole again....
Mild rat rod? It's not beat up and only rust on it is the right rear lower quarter and it's minor. I'd had the doors and fenders off of it and they are mint! This is the car that I got down to 2950 from 3370 while driving it and using the factory AC. /6, auto and I stuffed in an 8 3/4 with 4.10 gearsNeat beater. I'd turn it out on the street!
LOL....meant to remove that oil pan back half before I took the pic. I use that to test the rear main seal before buttoning up a big block.Looks like it's supercharged?![]()
I bet you could keep it under 3,000 with a big block with aluminum heads, intake, water pump housing, water pump, etc…This is the car that I got down to 2950 from 3370 while driving it and using the factory AC. /6, auto and I stuffed in an 8 3/4 with 4.10 gears![]()
Had all of that....until my last wife decided to divorce me. Thing is, she leaving was the best thing that ever happened to me!!I bet you could keep it under 3,000 with a big block with aluminum heads, intake, water pump housing, water pump, etc…
Wish I could!! Read above....Get on that thang, man.
Now that she’s gone it should be easier to get all that stuff back!Had all of that....until my last wife decided to divorce me. Thing is, she leaving was the best thing that ever happened to me!!
That tire needed replacing anyway...and by the wear, an alignment.
Crap.
Thought this was the "What did you do besides....." thread.
Sorry.
Sittin on concrete slab....if weeds around it get taller than the tires you’d better gift it away
Wasn't too bad...but there were two other vehicles blocking it in so it wasn't easy to get around it.Did you have to dig it out?
That's where I'm at with my 67 wagon.
I'm itchin' to work on it but I only have so many free hours.
Just gettin all the stuff off the roof and clearing a path to the doors took two weekends.
...and then I haven't had any time until yesterday...
...and my wife picked up that bolt...
It can feel like winning the lottery!Had all of that....until my last wife decided to divorce me. Thing is, she leaving was the best thing that ever happened to me!!
