New member from Texas! 1968 R/T!
Dad's R/T
9:04 PM
League City, TX
My 1968 Coronet R/T! Bucket list car I picked up in September this year... My Dad bought a new 1968 Coronet R/T (QQ1 blue 4 speed) in May 1968 and I have been looking for a similar car for years... The car I bought is a non-numbers matching R/T in QQ1 blue with a 4 speed and some cool mods that make it "driver friendly"... It has power 4 wheel disk brakes, a Passon Hemi O/D equipped trans built by Brewers, QA1 front control arms with QA1 adjustable shocks all the way around, and large Hotchkis sway bars front and rear... The engine is a Six Pack setup like available in 1969 and up... Car has some dings and dents in its 25 year old paint but that gives it character and that much more fun to drive!! Since I've owned it, I have replaced the tires (due to age) and replaced the fuel lines and tank vent lines (this forum helped a lot with that research)... Plans are to fix a couple oil leaks, switch the clutch setup, and possibly swap out the Six Pack setup for a Edelbrock RPM/Holley combo to improve mid-range throttle response.. I plan on cruising in it a lot and just enjoying a different experience!
Welcome to FBBO from Ontario. That is a great looking '68 R/T! In my experience at area car shows, the '68 seems to be the rarest of Coronet R/T's. I am a model car builder, and coincidentally just finished a 1968 Coronet R/T hardtop, in light blue metallic, with white stripe and interior. I own a 1967 R/T, myself. Thanks for your pictures.
Welcome from cold Southern Ontario. Fabulous car with many great features. This will be a lot of fun to drive. :thumbsup:
Cool R/T... You might want to keep that Sixpack & try some tuning... When they are "right" mid-range throttle response can be very impressive...
The car actually runs really good it just seems like you have to be "all the way" in the throttle to get that Six Pack singing! If I do swap it out, I will definitely keep the Six Pack setup in case I want to go back...
Welcome from PA. Nice ‘68! I had ‘68 QQ1 GTX I owned twice. The second time around was more fun. It was a great driver, and I didn’t worry about stone chips, with a 30 year old paint job.
When all six tip in things get exciting pretty quickly... More so with a four speed.... Most of the time you're running on the center 2bbl.... Getting the jetting/power valve/accelerator pump& secondary springs optimized can improve the drivability...
Nice 68 R/T
make sure to check out the Resto-Mod & Pro-touring
maybe even the Racers Hangout forums too,
should be right up your alley
looks sharp build it your way
