Road Grabber
- 7:04 AM
- Apr 14, 2020
- Sarasota Florida/NY State
So I've been watching a lot of episodes lately of Engine Masters and ran across this episode that seemed like a topic that would be interesting if not already discussed because I myself am in the process of refreshing a 440 with a hydraulic roller cam with hydraulic roller lifters which makes me very apprehensive because my original cam in the engine was a flat tappet purple shaft 284/484 cam that's been used for over 35 years without a flaw. It's been mentioned many times about new flat tappet cam lobes being wiped out during break in period due to crap steel ( or whatever...). I never had this problem years ago but it seems to be enough of an issue that many people have given up on flat tappet cams and have switched to roller cams.
The dependability aspect of the hydraulic roller lifters and durability was my first concern. I chose a Howards roller cam because that was supposed to be what the "upgrade" choice now since roller camshafts are used so much in modern day engines.
After watching this Engine Masters episode I was looking for some feedback and maybe some actual application experience switching out hydraulic rollers with solid rollers on a hydraulic roller cam. Note it is mentioned in this video that solid rollers are not recommended for street use because of aggressive profiles.
1. Will using a solid roller lifter stand the test of time without shedding roller bearings throughout the engine and ruin it? Has this issue been "solved" by using bushed solid roller lifters? Or even hydraulic roller lifters for that matter. Is bushed a better roller lifter choice? Would choosing a lifter that is bushed have been a better to protect the engine if the lifter fails?
2. Am I over thinking this? Will the Maximum Effort Retrofit Howards hydraulic roller lifters that are made by Gatorman be reliable enough at higher rpm and not float so long as the spring pressure is right? Howards recommended 175# seat and no more than 425# at full lift.
3. Would it be better to use a solid bushed roller on the hydraulic roller cam to get the full benefit of the lobe profile design especially at higher rpm since the hydraulic roller lifters are prone to float above 5500 rpm?
5. Has this swap to solid roller lifter on hydraulic roller cam been proven for durability? The comments after this video episode say it has been used many times before without issues as long as the valve lash is correct. - .004 lash?
6. Is the hydraulic roller cam actually "easier" on the solid roller than a cam designed for a solid lifter making it compatible for the street?
7. Lastly barring further comments, if this is the best thing since sliced bread for hydraulic lifter "deficiencies" and what if any modifications or changes are needed besides maybe longer pushrods? And know proper valve lash?
Watch this episode below and tell me what you think. Pretty interesting.
When they switched out to a solid roller lifter there was both a torque and hp gain.
Engine Master Episode Link
