Sundays......
fresh page...... and change is in the air :)
last Saturday was our anniversary and the bath tub in the "open projects" thread was a gift...... so obviously nothing happened with The Mellon.
I trashed the shop, the yard, and the house over the past couple months...... and I have family coming in this week :BangHead:
with weather moving in I spent a couple days outside cleaning up, helped the wife inside the house, and eventually got to cleaning my hell hole.
I spun the AMX 90* and opened up an area where I can put a table, and roll the engine in and out of the safety of my shipping container.
I need to button the engine, and build my dash....... the bodywork thing was kicking my ***; so glad that's over.
I really need to get back to some sort of normal; and buckle down on the other cars for a bit. I don't see the engine and dash screwing me up like the body did..... so Sundays will continue :steering:
honorable mention........Jeff, @T2R9 took my trans home with him, went through it, and brought it to Carlisle..... Thanks again :) ; one less thing to worry about
Do you ever wonder how long a fresh transmission can sit before you use it?
My first thought would be that time should not be an issue, that any quality rebuild should work the day you buy it or ten years later if it was in dry storage.
I had a 727 that was rebuilt for me, I waited for my existing trans to show signs of failure so it sat for almost 3 years before I used it.....and it was AFU from the start.
I had a guy rebuild a ThermoQuad, he said to install and use it right away. I didn't and it pukes gas like the floats are stuck down.
how long does bearing assembly lube last? ...... asking for a friend :rolleyes:
I had a small block 727 fresh rebuild but sat dry for about 10 years. Upon installation and filling I had 2 dry cracked seals....the cup seal where the shift/kickdown lever shafts go through, and the pivot pin for one of the levers....back by the tailshaft. Both were easy fixes....otherwise the trans performed well after setting that long.
Thought you were mourning the Eagles loss to the Giants.
they destroyed the Chiefs for the world to see in the Super Bowl, I can run on that for a while....... in 2017, They beat Brady on his greatest passing day.
They don't always win the Super Bowl, but when they do, it's epic :nutkick:
Do you remember what kind was used? If it's the oil based red stuff you should be good. If it was some kind of grease it might have dried out or hardened.
this was a serious question :poke: ...... guess I'll pop off a cap and and take a look
We will use a drill and pre-lube the engine, so I'm not so worried about bearings. Given the issues with flat tappet cams during break in, I AM worried about that during startup. I'd re-lube the cam and lifters.
yeah, I know; I needed to pull back a little....... everything else around here was starting to suffer.
there isn't much more I can do to the car itself until I free up the rotisserie; the exterior is ready to sand/paint...... I'm ecstatic it's this far along.
I always work on Sundays, today I serviced my heater and put 100 gallons of diesel in the tank; yesterday I spent 10 solid hours on the Challenger (currently on the rotisserie) so that sort of counts.
I'll be buttoning up my engine over the next few weeks, nice change of pace....... I have a lot going on, but Sundays will continue. :thankyou:
Any engine pictures?
I will....... I don't want to get into it right now, as the shop is a very abrasive environment for the next few weeks
as mentioned earlier, there isn't much to do the the car until the rotisserie is free.
I suppose the plan is to get the bottom of the car, hood, and trunk compartment painted...... then I can pretty much start putting it together; drive train, brakes, suspension......... so anything toward freeing up the rotisserie counts.
The GTX is nice enough and far enough along to warrant a plastic cover.
the Challenger on the rotisserie won't be on it for long....... I hit it pretty good today.......it pays a few bills, too
The Pumpkin is waiting patiently, and will get some special attention soon......... I have a plan, sort of :blah::blah::blah:
Mark's lower control arms in the process of being rebuilt by a couple of buttheads in PA. :poke:
First had to press out the old bushings - this was done by welding large washers to them and the pressing them out from the back. It works nicely without hacking up the lower control arms.
can't wait to do this to mine :rolleyes: ........ Jeff's Pumpkin will make it to the rotisserie next (same treatment)........it's all part of getting my ducks in a row
I have the GTX engine, dash, and seats I can be playing with (scored a set of headrests yesterday, winning).........it's all on the list, just playing a little catch-up; these cars are a lot of work :blah:
yup....... I got screwed out of a couple months......more like a hand job......with sandpaper
shop is spotless tho :blah:
