- 1:24 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Some day I'm going to install a fitting and gauge and measure crankcase pressure. I've often wondered if there is sufficient flow through that itty-bitty pcv hole to create vaccum in the crankcase. And conversely are breathers sufficient to neutralize crankcase pressure.
Really all you need to do is lay a piece of paper over the valve cover hole. If it sticks you have negative pressure. Only way to achieve this is to create vacuum in the crankcase from the intake manifold. Factory uses a hose from the carburetor base to the valve cover. One valve cover has the hose with a pcv valve and the other valve cover has a breather. Without vacuum in the crankcase, pressure can result in oil leaks that normally wouldn't happen.
Are you sure it's not the crankshaft seal?
