Sheetmetal question.
chrger1967
12:55 AM
What Sheetmetal do I need to repair the sections where the lower fenders bolt too? I have the lower fender patch panels, but it looks like I need the inner fender braces as well. I'm just not sure what the sections I need where the fenders bolt up to. I've been looking on AMD's website, just unsure of what else I need. Thanks guys.
outer rocker panels and or inner rockers depends on how much rust you have.
This is what I was mentioning. Aren’t the rocker panels below the doors?
That is a splash shield that bolts in. Find the bolts with large washers, take them all out and see how large it is.
I circled two bolts and the edge is between the two vertical lines.
I thought your were talking about the bolts that go into the pinch weld area. Looks like the splash shields are only made for 68-70 B-Bodies from AMD.
I don't keep up with repops. It is a 2.5 foot tall panel, about 6" wide held on with many bolts.
