There is exactly ZERO chance I would buy/use/suggest those rockers.... Two bands of narrow rollers chewing on the rocker shafts never ends well.... If it were a rotating motion so the rollers were constantly moving/rotating it would be fine, but rocking back and forth causes the same roller to work on the same little bit of shaft till it starts eating into he shaft... Bad idea... You want a bronze bushing in that location...
Personally I'm not a big fan of rollers when running less that 600 lift, cause a quality set is expensive & for low lift it really isn't justified....
If you need them than don't buy a cheap set.. If the pin that is the roller shaft fails in any way ugly things can and do happen... I've seen the pin get loose and slide out, I've seen the pin break, I've seen the aluminum around the pin break...
In any of those scenarios you have a couple really bad things happening, the fork where the roller lived is now pushing on the valve spring retainer instead of the valve, how long till the keeper pop out and the valve drops? Sometimes your lucky and catch it before that happens... Sometimes you have very little left to save...
I'm sure the good brands fail, but I haven't seen many that failed.. The cheap ones? Just type roller rocker failure into google...
There is a reason so many old timers suggest ductile iron rockers...
