CrazyBoutRacin
Would that happen to be a yellow wire from the factory?
It uses a brown colored wire.
brown.Would that happen to be a yellow wire from the factory?
Post a picture of what you have. Have you looked at wiring in a FSM?Would that happen to be a yellow wire from the factory?
This is on the ballast resistor itself, not the distributor. I have to supply 12v to the coil positive. Three on the input side, two on the output side, of which one is the coil positive. The other I can’t figure out. I hate to throw 12v on it and hope for the best.
im sorry you’re right. Here’s what I’ve got. On the left terminal it has two wires, brown and dark blue. I believe the dk blue goes to the pos on coil and the brown goes to bulk head. On the right terminal it has three wires, I think this is the 12v side. Two dk blues and one yellow (I think). One dk blue goes to bulkhead, another blue goes to voltage regulator. The yellow looks like it goes to the bulkhead connector.brown.
To add a little to the instructions already noted for bypassing the ballast resistor and what the ballast connections should be, see the following:
Simplified wiring diagram of a stock 1965 point ignition system highlighting the ballast resistor connections:
The wire colors in the drawing are what is originally in a 1965 B-body with this setup. Description of the circuits in this diagram are as follows:
- Circuit J3 connects to the ignition switch "Ignition START" via bulkhead terminal "D".
- Circuit R5 which junctions with circuit J2 at the regulator to the ballast resistor, connects to the ignition switch "Ignition RUN" (J2) via bulkhead terminal "B", which becomes circuit J2 behind the bulkhead.
- Circuit J2A connects from the ballast resistor to the positive (+) terminal on the coil.
To bypass the ballast resistor, connect the J2A & J3 combined terminal to the J2 terminal, with one of the methods already described, or another of your choice.
If there are other connections, or other wire colors, or other deices suscha s a later style voltage regulator, things have been changed. Adjust the wiring adaptations accordingly, but the simple bypass of the ballast resistor should be the same.
I’m not sure about the alternator. I haven’t had it very long, but it is a running, driving vehicle and it was charging. I do plan on changing to a one wire type soon. I think I’m back on track with this deal but I would like to ask one more question. Both wires on j2a and j3 look to be 14 ga wire. All the wires on the other terminal appear to be a combination of 16 or 18 gauge. Does this mean I’m supplying the coil positive with undersize wire? The distributor instructions recommend 14ga/15 amp supply. It looks like I’ve got 16 or 18 gauge supply wire feeding 14 gauge wire with 12v to the coil.Diagram in post 24 is your friend. The only addition for electronic voltage regulator is an additional blue wire to the alternator. ( from the blue power circuit. )Hopefully you have the matching dual field wire new style alt.
This is a big help. I believe there has been a voltage regulator change. This one is a thinner version of the original I believe. It appears to have a circuit board in it. Would that change the wiring any? I have one wire connected to the input side of the ballast resistor that goes to the bulkhead connector and that’s it. I don’t have continuity from any wire on the ballast resistor to the voltage regulator.
Your runs are so short the gauge is not critical.I’m not sure about the alternator. I haven’t had it very long, but it is a running, driving vehicle and it was charging. I do plan on changing to a one wire type soon. I think I’m back on track with this deal but I would like to ask one more question. Both wires on j2a and j3 look to be 14 ga wire. All the wires on the other terminal appear to be a combination of 16 or 18 gauge. Does this mean I’m supplying the coil positive with undersize wire? The distributor instructions recommend 14ga/15 amp supply. It looks like I’ve got 16 or 18 gauge supply wire feeding 14 gauge wire with 12v to the coil.
Makes sense. I think I may change a few things when I re-wire. I sure appreciate your help!Your runs are so short the gauge is not critical.
Do you have an electric choke?Makes sense. I think I may change a few things when I re-wire. I sure appreciate your help!
J2A circuit becomes brown wire on factory electronic reg setup since 70. I guess to save from confusion with the wire running to the alt field along the same harness, on same blue, just diff gauge.The diagram has been modified for the 1970+ alternator and dual field connection alternator. This connection diagram shows how it would be electrically added. Physical wire layout and possibly connection points could vary some depending on how the installer performed it.
It’s a Holley with an electric choke but not connected yet.Do you have an electric choke?
Want to thank everyone who chimed in with advice. Everything worked out great and I learned something with everyone’s help! I replaced the distributor and balancer due to an old balancer that was separating and a tired old MP distributor causing the car to not run smoothly. Starts and runs like a top. Now to get this Firecore distributor dialed in! Thanks for everyone’s patience and time!Need some help. Installing a rtr Firecore distributor on my 65 Coronet with a 440. Instructions say full 12 volts. So I can just connect all wires on both terminals of the ballast resistor with a jumper? There’s two wires on the output side and one is the coil positive, but I’m not sure where the other one goes to. Is there something else that needs the voltage decreased like the coil? Appreciate the help.
I didn’t add pics because with folks help I got it figured out in fairly short order. It was a ballast resistor with two terminals. I gave the number of wires on each side with the corresponding colors. I got the assistance quickly, which was appreciated.And yet still no pics. U have been asked a few times. What don’t u get about that? They would save a lot of time if we could put eyes on it. Kim
