mikeynags
Looks like my overheating problem maybe related to the pump. Anyone ever have any issues switching to an aluminum water pump? Any considerations when going to an aluminum pump?
Thanks
Thanks
they dont rust and 440 source has them almost as cheap as steel. milodon moves more water
Thanks
How can I check the air-flow thru the rad?How's the air flow though the radiator?
So, the higher fin count does not mean more cooling power or surface area for cooling right?My (ex) Super Bee was a #'s 383 auto car. Still had the 22" radiator in it, although I added a shroud and clutch fan (hard to find one short enough to fit). I ran a 180 thermostat and an "a/c" waterpump and never had any issues with it at all.....even screamin down the highway twistin 3700rpm with the 3.91 gears.
Find what is causing your problem and don't just try to mask it.
I forgot. That 22" had a 3 row core but did NOT have a higher than original fin count. Do NOT run a radiator with a higher than O.E. fin count
Yes, it is a Mopar rad, still has the emblem stamped on it. I'll get the #'s on it tonight.Is it a Mopar radiator? If so, what's the number on the top tank?
I see 2 numbers on the top of the radiator. One is by the Pentastar emblem which is 38086 and the other number is 3443952.Is it a Mopar radiator? If so, what's the number on the top tank?
