Polsky
Here it goes. I have been doing a ton of reading on this topic but would still like more insight. I am looking at doing a budget rebuild on a 1968 440. Currently, the engine runs rather well but is using some oil. I will break down what I am going with and what I need advice on. There are so many opinions out there but hopefully someone with a very similar build can let me know what they have, the positive and negatives, and time/dyno. To sweeten pot, one of my co workers bought a 2011 mustang with a tune, headers, catback exhaust, and is really talking down Ma Mopar:angryfire:. I would really like to blow his doors off but I also have a family so the budget is limited. Thanks in advance.
Block- 1968
heads- stock rebuilt 906 heads (This is what I have and cannot afford aluminum at this time)
Crank- stock forged. This will be turned as needed.
Rods- LY that will be reconditioned with ARP bolts.
Cam- I currently have a MP48, the old hemi grind. I like it but am sure their are better profiles out there to match my combination. Hydraulic suggestions only.
Stock push rods
Stock rockers
Intake is a single plane torker
Pistons- Looking at KB237 but open to suggestions. Must run on 91 octane.
Windage tray.
750 Holley vacuum secondary carb. Will hopefully update to a DP. Any suggestions?
1 7/8 headers
This is going in my 67RT(3800LBS), 3.55 gear, and rebuild hi stall from 1968 RR. The engine will be street balanced.
Block- 1968
Stock push rods
Stock rockers
Windage tray.
1 7/8 headers
