steve from staten island
- 7:08 AM
- Sep 24, 2012
- staten island,ny
Two barrel carb on my 383. If you pump the gas maybe flood the engine a little and I'm not talking pumping it till the bowel is empty or continuously cranking it,should you get and gas leaking out the shaft bushing for the butterflies? The guy who did the carb told me he was going to re-bush the shaft then told me when i picked up carb it didn't need it done,when i brought it to him originally at one time i must have flooded the engine and gas was really coming out those bores very bad so i thought it was worn and sucking vacuum then.. Thanks
