atrick
Need some tech info and some performance advice. I'm trying to find an A833 4 speed for my 72 charger. It's going behind a 400 that I hope will be around 450-500hp. I know I can buy the exact setup from Brewers but I'd like to try and save some $$$. That being said, I know the differnce between saving money and be a cheapa$$. I want the setup to be right and last for the long hull. I've found an 23 spline OD trans for a nice price with an iron case, long tail house with dual mounts, and 5.125 bearing retainer. Can I make this work properly with out chopping everything up and staying cost conscious? Will the OD gears/shafts hold up for the long hull? Pretty sure this is a late 70s truck trans. Anything I need to know about making this work? Bell housing issues? If this won't work what are my other options besides finding the exact 70+ trans with long tail. Thanks for your help.
