magvan
Just wondering if anybody has a way to measure an intake manifold to find out if it has been milled or not? Turns out the heads on my 440 have been milled an unknown amount. I had an aluminum intake that I installed and the engine always seems like it has a vacuum leak yet I could never find it using conventional methods. I remember the bolt holes being hard to line up and get the bolts started but just barely off. I seem to be getting a very slight vacuum leak through a couple of the bolt and I believe under the valley pan. I have the original intake that came off of the engine and I kind of compared it to another Aluminum Intake I have and I don't see any real differences where the bolt holes are at the manifold is a different overall width but then again that's a cast iron manifold to an aluminum one.
So anyway good places to measure from or ways to tell if the original manifold had been milled or not. The engine was not running when I bought it so I don't know if it had a leak or not
