Frank: The throttle cable has two parts. The inner cable itself and the casing that houses it.
Yea it's always been like that. I disconnected it but the carb still doesn't budge it won't go back forwards so I'm thinking a new carb might be in order and maybe a new throttle cable.
The plate is what's on the side connected to the cable right? It moves back but will not go forward at all now to where it's supposed to be. My friend has an old carter he's gonna give me and I'm gonna try to fix mine if not I'll get a new one.Did you check throttle plates for looseness like dvw said? Sometimes the cause is that easy.
Yeah thats my next step. Disconnected the throttle cable and cleaned the carb with everything but it just won't move forward, it's way too high. Don't worry I fixed the transmission spring shortly after taking the photo, thanks for the tip.Throttle plates are the round plates attached to throttle shaft. Easier checked if carb is off engine.
SentI just got a parts motor in it has that tiny little carb on it looked decent . If you want I will pull it apart if it is a rebuildable carb witch is assume it is I'll rebuild it and send it up to you . The kit should be fairly cheap bid guess $12-15 bucks plus shipping maybe another $10 bucks so say $25 or so ,I know autozone sells the carb new rebuilt for around $200-$300 it's up to you I would do a quad swap I have a spare intake and two eld carbs I can rebuild one of them if your interested in that route but shipping might he high on that one since the intake is heavy p.m. me if you need my help
