dodge68charger
Tried To Start My Car Earlier and Found There Was No Spark At The Coil.. I Am Running a Pertronix 3 Electronic Ignition In The Coil.
I Ran The Black Wire To The Neg Side Of The Coil And The positive Side To The Pos Side Of The Coil..
I am Running a Voltage Regulator In The Car and Hollowed out The Back Of The Ballast Resistor And Jumped It So There Is No Resistance..
I Do Not Have any Other Wire Going To The Positive side Of The Coil. Which Wire Do I Use To Provide a Keyed Ignition To The Coil. Thanks
