I've been helping the neighbor kid get his '71 chevelle going (I know ugh) he had the 350 built for 350-400 hp and is running a 750 demon carb. After going through the steps trying to correct an overly rich idle we took the carb apart and found one of the primary idle air bleed passages did not let carb cleaner or compressed air blow freely out the other end like on all the other passages (which can't be helping get air into the mix)...I suspect a shaving or casting material may be lodged in there (as has been reported with some older demons) I've heard of using fine wire like guitar string but never had to do it, is this safe? Don't wanna put scratches in there. Or other methods? Thanks!
