833 question
davek
10:08 PM
columbia SC
were on the passenger side will I find the 3 inch pad with numbers? I think it is a 71 do to the side cover.
thanks Dave I only have 1 mounting pad for shifter.
It is a pretty obvious pad, but pre 68 manual transmissions did not have them. You can't go by the side cover that is on there now. You can't go by the tailshaft housing that is on there now either, but one shifter pad is pre 70, more or less.
anyone know were to look up casting # on my 833
Brewers has a lot of good info on their website
have been looking at there site,no info on casting # for years. Thinking it could be 67 do to no serial-vin numbers. Only way to know if 18/23 spline is to pull it.
casting numbers 0-86581 n tail c86707 27 inches long only 1 shifter mount. side cover looks to be 71 dont know how it could work.
Pull the bottom inspection cover and have a good look. You should be able to see/count the splines peaking though the pressure plate assembly... unless you have a lakewood scatter shield housing..
Excuse me for hijacking, can anybody tell me the difference between a 23/18 spline 833 except for incoming axle and maybe bearing? Some say some 23's came with 308 bearing? Is house casting the same? Yes i'm gonna get a book.
And.. Just visited Brewers!
quote: New replacement gear set as used in 1965-1970 18 spline Hemi transmissions with 2.65 to 1 low gear, can be used in any A833 transmission to convert to 18 spline. Includes input shaft, cluster, 1st, 2nd and 3rd gears
