anyone know what this clip is for on a 69 GTX
revmaster
10:57 AM
Winnipeg Canada
I thought I removed this clip, off the rear of the gas tank by the filler tube. Screws to the bumper bracket to hold the tank up at the back, but it doesn't fit. Does anyone know what this clip is for I have a 69 GTX.. The clip that it shows in the book is a lot different. Thank you.
For Trans neutral safety switch wire. Pretty sure.
Thanks for the replies, . Ill check under the transmission, I did replace neutral safety switch. Thanks for the info. helps me know where to look . ill check those areas.
Re your original post, if it helps, here’s a couple pictures of the wiring clip that attaches to the filler tube bracket for a 69RR....Jim
