Toolman383
New Member
I'm looking for anyone who has used a "Right Stuff" front disc conversion kit on a 65 belvedere. The spindles and caliper brackets were already mounted when I purchased the car. I installed the calipers the way they were marked (L) driver (R) pass. and the bleeder valve was facing down to the right. The instructions says the bleeder valve "must" be pointed up...so as instructed I swapped the calipers. The bleeders are up now, but at full turn the caliper hits the shock. It states in the instructions that the calipers can be mounted on the front or back side of the wheel...to do that I need to remove both spindles (and brackets) to swap them. I just don't want to do that and then find the calipers hit something else or the flex brake line doesn't work that way.
Is anyone running a "Right Stuff" front kit with the calipers on the front side of the wheel? Any info or suggestions would be greatly appreciated.
Thanks.
Terry
Thanks.
Terry
