Bill Monk
This an old article on alignment I came across this morning. While it's a good article, I found you can't hit these numbers on caster and camber without tubular control arms. I was able to achieve the typical street performance numbers from the chart using tubular arms on a 68 barracuda I had several years ago but with stock UCAs, you can't get close.
Anyway, what are your thoughts on the chart and are you using factory specs or going with your own?
https://www.allpar.com/history/mopar/front-end-alignment.html
