biggerthanyou
New Member
Hey all. I been researching my problem for 2 months and I'm getting nowhere. Conflicting reports on every post. Just need a straight answer from a person that has completed my nightmare. Here goes.
1 I have a 65 Plymouth belvedere with a 273 904.
2 I have a brand new 1984 360 LA I want to install.
3 I finally found the motor mounts that needed to be changed
4 finally figured out the oil pan I needed with pick up
5 have the wieghted fluid damper
6 have the B&M 904 flexplate
7 running headers
8 ok my last issue. Can I run the converter already in the car? I'm hearing no and yes. I'm hearing with the B&M flexplate I can. Then I'm hearing I need a 360 converter. Please please only respond if you have done this. I'm thousands in the negative on this so called easy swap I'm trying not to waist any money on maybes.. thanks for whoever can save me from this nightmare.
7 running headers
