64FuryJohn
will an M/T drag radial 295x65x15 on a 10" rim fit a 64 Fury with inboard springs and no mini tubs? Should be rite around 13" section width.
I'm not familiar with 64 Fury's so can't help in that regard. Without knowing the backspacing it's hard to help but 13" sounds really, really tight. My Charger has 14" wide tubs, I stuffed 305's under it but the offset had to be spot on in order to pull it off without any rubbing. Break out your straight edge and a tape measure and go figure it out, easy task.will an M/T drag radial 295x65x15 on a 10" rim fit a 64 Fury with inboard springs and no mini tubs? Should be rite around 13" section width.
....Break out your straight edge and a tape measure and go figure it out, easy task.
But its SO much easier to just type a question and let someone else do all the hard part for you. You know, actually "thinkin" and all that.
