- 7:21 PM
- Dec 3, 2020
- western Maryland
So, while working on my dash lights and horn relay I discovered a piece of plastic (broken) bolted to the underside of my dash. Once I got the cluster out, I looked down into the dash...and found the rest of it. It's the plastic piece that's supposed to hold the push-pull cable for the vent.
Has anyone ever successfully repaired these? Or is a replacement readily available (and install-able without too-major surgery)? I think I may try some fiberglass mat, and some good ol' JB Weld, to see if I can't get it together enough to be able to use it again...
