bbudnyk
New Member
starting to fit my quarter panels and found that there is a bracket in the way when I go to place the quarter. My questions are as follows:
1. Can the bracket in the picture be removed and reinstalled after the quarter is on?
2. Is there any tricks to getting the quarter panel under the roof skin? It's pretty tight against the support underneath and should I just gently pry it away?
3. I'm fitting the outer rocker. Are there any tricks or tips for final install?
Thanks in advance
Thanks in advance
