thanks for passing this tip along, I am going to try this out soon...Get 2 5/8 bolts that are 5 inches long, cut the heads off, cutoff wheel works for making a slot for a flat head screwdriver. Install the bolts onto the bell housing and slide the trans onto the bolts. This helps align the trans an it’ll stab right in. Install the upper 2 bolts, take out the bottom guide bolts and install the bottom 2 bolts. Done!
