Piston recommendations
Sonny
It’s all fun til the rabbit gets the gun.
10:43 PM
Florida
Rebuilding my ‘78 440 and made the following changes:
Swapping 452 heads to 440 source aluminum stealth heads.
Cam is stockish summit 6400
block hasn’t been decked.
Stock stroke
0.030 bore.
My kb 184 pistons with raised pad need to be either replaced or pad milled down.
If I buy new, what is a good affordable piston to get me around 10:1 compression? Is it better and/or cheaper to mill the pads down?
Thanks
Sonny
I used Speed Pro Forged pistons in my 75 RV 440. https://www.summitracing.com/parts/slp-l2355f30/make/dodge
KB 237 is close to a zero deck and will get you there with the Stealth heads. As long as you aren't boosted the hypereutetic pistons are nice. I'm running the same pistons and heads and am around a 10.2:1 with Felpro gaskets.
I’d run some ICON flat top pistons. Forged pistons plus the thinner 1/16 rings to free up some power.
I'm running & recommend Icon's too... However they are considerably lighter which while it is a good thing but because of that they will require a balance job...
