What's it Worth 14in original rallys professionally widened
Lineman
8:43 AM
Glen Burnie, MD
Cleaning out the garage, years ago I had the local dirt track champion widen these 14in rally wheels for me and I ran them on the back of my 1970 charger. I am sure the purist say I wrecked a good wheel but back then that was the option if you didn't want to go aluminum. They hold air and look good..run good and are safe..
I am open to offers..
Pick up in Harwood, MD very, very perrifable..
What is the backspace.
That will give somewhat an idea of what cars they could fit.
WIW? 14" Rallys regardless of width aren't worth a lot any more. It's hard to find tires nowdays. $50 each would be a stretch IMO.
14x7 would be more sellable than 14x9.5
but if it’s got too little backspace it going to fit more limited body styles and not very wide tires (if you can find some)
The backspace should be the same as a stock wheel, looks like the band was added to space out to th outside, by the 3 extra inches. they worked fine on the 70 charger.
Think someone would like them or find value in them? Think I could get $100.00 each?
I don't know what I was thinking back then with this 14in wheel, guess it's what I had or could get..
Asking $100/ea you need to actually measure the backspace and take a picture of that to include with ad.
A stock 14x6 will not be 4.25” backspace that Mopar 15x7’s and ramcharger 15x8 are.
Without measurement proof, they are $60-75/pr
With measurements. $100-150 pr
Problem is there aren’t any 14” tires wide enough to need a 9” wide rim. And the visual weld line is a turn-off.
Plus: they don’t make a new 14x9 if someone is really looking for some.
Powder coated brand new 14x7 are $177/ea. cost me $600 to blast and powder coat four rims 10 months ago.
Thanks for all the helpful replies. Looks like the back spacing is original? I will call it 4in back spacing.
Plus there aren't trim rings made for those. Sorry. Not worth much. Balance and out of round is always a question on modified wheels and shipping will run $40+ each which jacks the total price up for a less than perfect wheel. Ask $50 each and cross your fingers. Start a proper sale ad when you are ready to sell.
To be honest....
The largest 14" tires I know of currently available are 245/60x14, and they are too small for a 9.5 rim, or 8.5 for that matter.
And the only 245 is a radial t/a. Other that those, 235/60 is the only common tire available.
So, if there are no tires that fit.... what are the rims worth? $20 for the pair? Sorry.
What were you thinking? Probably not that the supply of wide 14" tires would completely vanish. I had M50X14s on 14x10 rims on the back of a box Nova gasser, that were 11" wide. 40 years ago!
I haven't seen any 14s anywhere near that wide in 30 years. I wouldn't wanna run thirty year old tires either.
The black rims in the bed of your truck under these two rally rims are probably work more each.
Thanks, that is another question. Three of those are 15x5s and one is a 5.5.. original steel wheels.. I guess they are just good for spare tires really? But what can I ask for them?
Need to look at the stamped part numbers near the fill valve. And ones inside the rims stamped.
Take pictures off all stamping and show here on another thread. Could be something valuable.
At worst, easier to sell and worth as much as the widened rally's.
245/60-R14 is what is on the wheels now and I see them out there in stock.. maybe the wheel is 9in.
What size tires are on them now?
