1964 Dodge ignition switch bezel
500Hardtop
2:36 AM
Aurora, CO
Does anyone have the tool to remove or install the bezel on the ignition switch?
Thank you,
Dave
If it is the same as a 64 Fury, I loosened the bezel by using a pair of needle nose pliers.
Small tips, stuck into the 2 holes on the inside edge to loosen and then unscrew the rest of the way by hand
Ed
MF1742 - 1962-74 Mopar; Washer, Wiper, Headlight Dash Switch Bezel Nut Removal Tool
I have this tool it will not fit the ignition bezel
I missed that, thanks. I'm going to delete post because i don't want to pass on bad info. Good catch.
