grubby65
I am in need of suggestions to help me solve the cooling issue with my 1964 Dodge Polara. Here are the specifics for the car:
1) Mild 383.
2) Power steering and brakes.
3) Automatic Transmission with separate fluid cooler.
4) Champion 3 row radiator.
5) Air conditioning.
6) Electric fan.
7) High Flow 185 degree thermostat.
8) I have not pulled the water pump to check its condition.
9) Non-clutch "flex" fan.
10) Radiator fan shroud.
11) Recent coolant change 50/50 mix.
The problem I have is when the ambient temperature is over 85 degrees the water temperature runs around 205 without the air conditioning running. So, in all reality I never am able to use the air conditioning when I actually need it. It seems the electric fan really doesn't do much. On one hot day (95 degrees). It let the car run at an idle, with the electric fan on, and the water temperature got to 215, this took about 15 minutes.
Here are some pictures:
A few thoughts I had is there may be an issue with the proximity of the Air Conditioning condenser and the radiator. There is approximately a 1" gap between them. The other is the Champion radiator, it is less than 1/2 the cost of say a US Radiator. Sometimes you get what you pay for. Anyway, if someone has suggestions I am all ears. I don't want to go to the expense of buying a new radiator if it is something els.
1) Mild 383.
6) Electric fan.
